262 gas motor in a WD will it fit?
chris
03-28-2002 19:01:30
I've got a good 262 gas engine out of an A2 combine and my brother N law has an old WD with a froze and busted engine .I know the frame rails and steering shaft will have to be lengthened.Didn't the WD 45 diesel have a 262 motor,is it the same? It looked like a project tractor to me.will it bolt up?
chris
03-31-2002 19:50:44
 Re: 262 gas motor in a WD will it fit? in reply to chris, 03-28-2002 19:01:30
thanks ,I thought it could be done ,we''ve started taking the WD apart ,got to start somewhere.Also does anyone know the horsepower of the 262 it's out of a a2 gleaner dont know the year
L. Hud
04-06-2002 18:31:38
 Re: Re: 262 gas motor in a WD will it fit? in reply to chris, 03-31-2002 19:50:44
I think in the combine it was rated at about 60 hp. Good luck on the project.
L. Hud
03-31-2002 16:23:20
The 262 or 230 will go into the WD. A WD45D uses the same frame rails as the WD. I have friend that put the 262 in a WD. You need the plate from the back of a 45D engine to mate up. Or make a plate. The WD flywheel is a little short to reach the starter. Have to move starter ring back just a little. A 45D flywheel works perfectly. Will have to remove the front end to get engine in and remove all crank mechanisms. After engine is in then you can put the front end back in. Have to fabricate a front motor mount. Bend frame rail down a little for govenor housing. May have to cut frame rail for oil filter. The radiator will have to be moved forward over pedistal. Radiator will have to be modified by moving lower outlet to one side or find a 45D radiator. The hood will have to be lengthened about 6inches. Hope this helps. Good Luck
Phil Munson
03-28-2002 21:52:16
The AIIs that I owned had a 230 engine, not the 262 engine you referenced. The WD-45D had a 230 diesel, the D-17 diesel had the 262D engine. I am not at all sure you are right, in thinking the frame, etc has to be extended. The radiator comes all the way to the front of the frame on the WD-45D, it is not at all set back like the WD and WD-45.
