Leaking fluids on WD
Jim Herbert
03-27-2002 07:56:36
I recently purchased a 1952 WD that is showing oil leakage at rear main plus hydraulic reservoir front seal is likely leaking. Based on anyone's prior experiences, would it be advised to try 30wt non-detergent in hydraulics or other easy fixes prior to mechanical seal replacement? Also, what would be a ballpark cost to replace front and rear main seals along with front hydraulic seal?
Ron
03-27-2002 13:21:11
 Re: leaking fluids on WD in reply to Jim Herbert, 03-27-2002 07:56:36
I would use it this season, if it is not too bad...maybe it will be ok...Ya never know, mine seep some, sometimes...expect some light leakage on a tractor...some dirt unseats the seals, at times... We have always used 10-30, or 10-40 engine oil in our WD-45 hydrolics, since they were new, and still do....
