Busted B block
gatractorman
03-27-2002 02:17:53
Dadgummit, didn't pay attention when I tore it down but was looking at it again the other day and my block is busted at the top between 1&2 and 2&3 guess I got some B parts for sale.
m spriggs
04-05-2002 11:15:45
 Re: busted B block in reply to gatractorman, 03-27-2002 02:17:53
Just finished re-building a a/c B with the same problem. I'v run it, checked the water & oil and all seems fine. should not be a problem.
steve
03-27-2002 17:17:36
what do you mean by busted?? a crack about the width of a piece of paper? how do the liners fit? listen to Dick, its probalby o.k.
gatractorman
03-28-2002 02:18:12
 Re: Re: busted B block in reply to steve, 03-27-2002 17:17:36
Yeah it's a hair line crack, haven't tried any new liners yet, but the old ones (cleaned up as best I could) seem to still fit ok. Thanks for your input.
Trevor
03-27-2002 16:08:55
Why not buy another block. Where are you? Maybe I can help.
Dick L
03-27-2002 04:28:52
I doubt you have a bad block, most B and C blocks are cracked at the top between cylinders. If they have not spread apart the head gasket will seal them fine.
gatractorman
03-28-2002 02:26:58
 Re: Re: busted B block in reply to Dick L, 03-27-2002 04:28:52
Hey Dick thanks for the info I was thinking mabye the head gasket would seal it as it is a hair line cracks.
kevin
03-27-2002 03:48:40
What all do you have, and where are you at?
