B to C, will it fit?
DaveJ WI
03-26-2002 06:11:01
Will a loader that is on a B fit on a C? My C has a factory hydraulic pump ,will it operate the loader and does it need added fluid capicity? What size front tires work best with a loader? Thanks in advance,Dave.
steve
03-26-2002 19:30:36
 Re: B to C, will it fit? in reply to DaveJ WI, 03-26-2002 06:11:01
there is not much physical difference between the B and C so it ought to slide on. the B is a wide front end, most of the C had narrow front, but yours might be a wide model. I assume your loader has its own hydraullic pump and you wnat to just use the factory version on the C. The C pump is a very low volume and high pressure system. Puts out about 3000 psi. Your loader probably is a lower pressure system and does it have a seperate hydraulic tank??? the C uses the transmission oil to work the hydraulics and it only holds 2 gallons of oil. You will need to add a reserve tank to the side or rear and plumb into the transmission case for "extra oil" and even then it will be slow on response, but will go up and down.
