U.F. Tractor
Roland Twerdohl
03-21-2002 11:43:59
I have an Allis-Chalmers Tractor, that came with the farm when we bought it. It has a front-end loader and three-point hitch. The engine serial number is 149 12255 R. The exhaust was left open and #3 liner froze and cracked. I would like more information about restoring it to it's former self,parts,pictures,ect.
Thanks, Roland twerdohlib
3
JMS/MN
03-21-2002 12:16:48
 Re: U.F. Tractor in reply to Roland Twerdohlib, 03-21-2002 11:43:59
The number on the engine is not the serial number of the tractor. We'll be glad to help if you can find the serial number. Check on the left side of this screen under serial numbers, go to Allis-Chalmers, and they will list model numbers and letters. Most serial numbers are on the transmission housing, the rear end, (visible from the rear), or in the case of the D series, on the left side, rearward of the engine, but not on the engine block- they are on the cast housing that the clutch is in. Check those areas and we will be glad to identify your tractor if you need help beyond what the board says. Also include info like hand or foot brakes, # of engine cylinders, # of transmission speeds, etc.
