Wd45 exhaust
Sid
03-21-2002 08:57:27
Does anyone know if the correct-original muffler had a bracket to the head and a clamp around it or just a plate bolted to the exh mnfld, and does the mnfld have a pipe coming out or does the muffler slide in?-thank you
farmerbrown
03-24-2002 14:25:33
 Re: wd45 exhaust in reply to Sid, 03-21-2002 08:57:27
The pipe threaded into the manifold would be an update to a D17 design which is a better system, but not original.
Tom
03-21-2002 13:59:32
Sid, The original muffler on the WD45 was made by the Nelson Muffler Company. There was no bracket; it bolted directly to the exhaust manifold with two cap screws. There are after-market mufflers that can be purchased that have the brackets. A few years ago I purchased two Nelson mufflers from the Agco Dealer in Nappanee, Indiana. They are a dealer that will make the extra effort to research the part number substitutions in an attempt to get the product that you want. Tom
Craig
03-21-2002 10:06:57
Just put mine back on last evenning
The braket off the head is factory
muffler slides into manifold also
Don
04-03-2002 17:32:07
 Re: Re: wd45 exhaust in reply to Craig, 03-21-2002 10:06:57
I secured my muffler with a 4" clamp that we also use to secure our 3 1/2" straight pipe when we go pulling. The straight pipe really lets the WD bark
Tom
03-21-2002 17:44:25
I don't remember any bracket to the head? Bracket to the manifold with two capscrews to hold it in. Exhaust ( bottom of muffler) pipe fits into top of manifold.
Craig
03-25-2002 12:46:39
 Re: Re: Re: wd45 exhaust in reply to Tom, 03-21-2002 17:44:25
my bracket attaches at the head manifold side of valve cover....two 3/4 in bolts ..... .
looks factory original
Its how my operators manual has it also
