D19G hydraulics
david l wilson
03-16-2002 22:15:42
my late d19gas has a 3 spool hyd. valve and the only way to keep the lift arms in the up possition is to hold the lever up until the pump by-passes. i also have a loader on it and the first time you try to lift it up it only raises a foot or so and stops in a minite or so the pump starts making noise and it will raise a little more and so on until it is up all the way after you do this a couple of times it works good also while it is doing this the lift cylenders shake alot. i have been told it may be the relief valve in the pump or maybe the hyd. valve. my dad had the dealer work on the spool valves 2 times with no change before i bought it. any ideas or suggestions would be appreciated.thank you in advance. david l wilson it does this all year around it is worse in the winter but does it in summer also.
