Allis B rear hub question
Gus
03-16-2002 12:50:13
Hi I am looking at a B in the local paper's classified section. It seems to have the rear wheel center sections from a C on it "the deep dished ones" with 5 lug bolts. I have seen B's with the flat wheel centers that look sort of like a WC's and only have the center nut and semi flat ones with lug bolts that seem to be reversable for a little bit of wheel offset. Was this available from the factory like this or did some one put some parts on it that they had laying around. It looks to have been the way it is for a while though and does seem to fit together well, I was just wondering if I was looking at a spare parts special. Thanks for any info. Gus
Bryan Smith
03-18-2002 07:15:52
 Re: Allis B rear hub question in reply to Gus, 03-16-2002 12:50:13
The parts book notes that hub is for something like a B "with the 40" to 68" tread option" or something similar (this from memory). My 1950 has it with the adjustable wide front end.
ken
03-17-2002 06:15:07
They came from the factory like that when you ordered a B with an adjustable wide front end.
steve
03-16-2002 19:05:13
sometime about 1950, or shortly there after you could buy the B with the 5 bolt hubs. I have seen several this way, and they are all 1950 or later models.
Robert in Md.
03-16-2002 19:31:25
 Re: Re: Allis B rear hub question in reply to steve, 03-16-2002 19:05:13
I have a l948 AC B with 5 bolt lugs purchased new by an uncle.
