Positive ground
Don E. Foster
03-15-2002 16:12:41
Today I had the generator checked for my WD. It was OK. The electrician suggested that I have the battery in backwards as I can't get it to charge. Could be that I changed it when I put it back together. He says most of those tractors were positive ground.
If I do go for a positive ground, can I mess things us in case it is not supposed to a positive ground?????
Thanks
Ron
03-15-2002 17:46:43
 Re: Positive ground in reply to Don E. Foster, 03-15-2002 16:12:41
AC-WD's were Positive ground...
steve
03-15-2002 18:29:03
 Re: Re: Positive ground in reply to Ron, 03-15-2002 17:46:43
the generator has two terminals. ground the "F" always. start the tractor and measure the voltage from "A" to "F" and see which is positive. Should be "F" on the original positive ground. Could be "A" if it has a newer 12 volt generator. dont have the regulator or cutout connected during the test.
