WD-45D needs more fuel/Hp
JDGnut
03-11-2002 15:36:29
We are pulling our WD-45D. Under a good pull it smokes, but it doesn't ever turn to the good black color I have seen other 45D's. The screw on the pump has been turned to about its max.. The injectors have only been set to the stock pop off psi.. We are planning to increase the injector pressure.. but are there any other injectors (bigger) that will work. (out of an Oliver??) What about the injectors out of a D19, are they bigger??? What about the pump out of a D 19?? Just looking for some more HP... Thanks for any info...
JDGnut
(Timing??? Advance the pump timing??)
