B hydraulics leaking down
Bryan Smith
03-11-2002 10:17:46
The hydraulics on my B lift fine, but leak down immediately after I release the lever. The service manual indicates this could be a problem with the relief valve or the discharge valve (I've included an image link below for reference - the valves include plugs 5 and 6 and associated parts). OK, so far so good.
Anyone have any hints on what to do here? Is there a seal I should be looking for, or would you guess that one of the valve balls is stuck open? Should I have to remove the valve seats, and if so how hard are they to remove without damage? How much of this can I do with the pump on the tractor, or does any work mean take it off first?
Your thoughts and ideas most appreciated. Thanks.
markp
03-11-2002 18:47:17
 Re: B hydraulics leaking down in reply to Bryan Smith, 03-11-2002 10:17:46
This may help or not but check this first. The B that I am working on lifts fine also, but the return spring doesn't work so I have to manually return the pump to the hold position if I don't place it exactly where it belongs the lift falls as well. I would check where it returns to before I would tear down the pump. hope it helps
