Which Parts Cross; If any?
LC in Bama
03-08-2002 18:19:04
Do any parts from other models of AC tractors cross over to the WD model. I quess I'm trying to determine if I have a larger pool of parts to choose from then just the parts made for or installed on a 48 WD.
Doug
03-08-2002 20:11:46
 Re: Which Parts Cross; If any? in reply to LC in Bama, 03-08-2002 18:19:04
Yes, sheet metal from stlyed WC (pre WD) is interchangeable, unless the WC does not have a starter, in which case the sediment bowl would be right above the start (not good).
'48 was the first year for WD's
Going forward almost all later WD and WD45 parts will fit except transmission which changed in '53(has curved gear shift lever and helical gears after that).
There are even some early (series 1 and 2) D17 parts in final drive, brake and engine area that will work.
