Oil pump
big mike
03-08-2002 16:25:42
does anyone make a replacement oil pump for my b?im rebuilding the engine and it only makes sense to replce it ,or?????im open to any suggestions,thanks
S.Ammer
03-09-2002 06:03:12
 Re: oil pump in reply to big mike, 03-08-2002 16:25:42
B oil pump is a vane type pump not gear type, it is still available new from Agco but they are expensive ( about $250.00 last year ). I have heard you can also rebuild them but don't know for sure. I always thought a rebuilt motor should have a new oil pump but that is just my opinion.
steve
03-08-2002 20:35:58
take it apart and sand down the gears and housing with a belt sander or surface grinder, to getthe gouges out. if no damage, then dont worry. after the parts look good, you need to install a paper gasket on the end cover to get .001 or .002 clearance between the gear and the housing cover
