Correct muffler for a B?
Bryan Smith
03-07-2002 14:08:20
OK, my 1950 B has an intake/exhaust manifold with one threaded bolt hole in it. So far so good. The current through-the-hood muffler looks like one for a CA - it has 2 holes in the side "sleeve" that fits down beside the manifold.
This week I saw a 1949 B with a manifold with 2 holes in it like a CA manifold. It had a through-the-hood muffler with the inlet pipe sticking into the manifold and a bolt holding it there (no side sleeve bolting to the manifold).
I know some B's had under-the-hood mufflers, others had through-the-hood mufflers. Can anyone shed some light on how to determine which was on what tractor? Or a part number? Even the parts manual is hazy on this one. I prefer a through the hood muffler but don't know which one to get ... or even which is the correct manifold.
Thanks in advance.
Matt
03-08-2002 13:01:52
 Re: Correct muffler for a B? in reply to Bryan Smith, 03-07-2002 14:08:20
Bryan,
I did the same thing you did last summer. I have a 49 B, and I saw a CA and looked at it's muffler setup. Same thing you describe. My tractor just had the thru-the-hood muffler, and nothing else. The muffler just clattered around when the engine ran. I went to TSC and they had a muffler bracket laying on a shelf, which sort of resembled the kind used on the CA, except this one only had one hole in it. This was perfect, because like your manifold, mine only has one threaded bolt hole too. So, I bought the bracket (the counter lady couldn't find a price, so sold it to me for $1.50). She said it probably came in some kit, but..... ....Anyway, I had to bend it a little to fit the manifold/muffler offset. Got a bolt and washer that fit my threaded hole, and also a standard muffler clamp. I used the clamp to hold my muffler and the bracket all together real snug. I also used some muffler gasket goop to seal up the seam where the muffler goes into the manifold.
Thats it. I'm sure someone sells the proper AC bracket that we both need, but it was just easier (cheaper) for me to buy the parts and make my own. Using the tractor today matter fact (nice weather), and it's still sounding good (muffler wise). I put this all together last November.
Hope that helps.
Matt
Dick L
03-07-2002 17:15:37
The below drawing will show you what came with the tractor. The above hood replacement muffler will let water run into the manifold around the lower pipe. I use them but I weld an exaust pipe adapter that will fit over the flange on the manifold to shed the water over the out side. I will get a picture of what I am talking about soon.
