12-volt conversion
Big Don
03-05-2002 17:59:01
I am a GREENHORN at tractor restoration.I recently purchased a 1947 B.Since this tractor will not be a show tractor,I would like to convert to 12-volt.What parts do I need?How do I do it?Any help would be greatly appreciated.
Glenn(WV)
03-06-2002 11:32:21
 Re: 12-volt conversion in reply to Big Don, 03-05-2002 17:59:01
Punch this link. It will work for your B.
Steve in NJ
03-05-2002 20:37:48
Big Don,
I've been reproducing new replacement wire harnesses for the B,C, Model tractors with the 6V system. Right now I'm in the process of putting together a 12V conversion with all the poop you need. Should be done in a couple of weeks if your not sure of what to get for parts. The kit will also come with a new bracket to mount the 10SI alternator to the B's engine block which I plan on designing to work with the stock adjuster arm on top in order to make it a snap installing. Just in case you were interested....
steve
03-05-2002 19:26:57
Don, the most common alternator to use is the Delco 10SI. Go to Auto Zone and tell them you want the standard alternator for a 1976 chevy pickup. You will get a 40 amp alternator with an internal voltage regulator for $35. There is a 1/4 inch lug on the back for battery connection. There are two spade terminals on the side to run the regulator. Make sure the two spades are in line, not side by side. In line means it is for a 1975-1985 GM vehicle and has an internal regulator. You will need a resistor or small light bulb in the circuit to drop voltage slightly and make it charge. Installation is pretty simple, just follow Dueys pictures. If you do buy it, get it mounted and we can explain more about the wiring.
Duey (IA)
03-05-2002 18:54:51
Big Don, Check out the info on my web page, it may have a lot of answers for you. Duey
Big Don
03-07-2002 14:25:49
 Re: Re: 12-volt conversion in reply to Duey (IA), 03-05-2002 18:54:51
Duey, The wiring diagram and part numbers were an answered prayer.You have made my day.Thank you very much.Maybe one day I can return the favor..... Big Don
big d
12-25-2002 11:54:46
 Re: Re: Re: 12-volt conversion in reply to Big Don, 03-07-2002 14:25:49
hey send one to me...do u have a diagram of 6 volt? Email it to me if u can
