B Tractor Transmission Swap
Fred M. Osmun
03-05-2002 15:25:54
I'm working on a 54 B.
Will a CA 4-speed transmission bolt up to a B
and if so can the B axles and housings be used?
Paul
03-06-2002 20:54:58
 Re: B Tractor Transmission Swap in reply to Fred M. Osmun, 03-05-2002 15:25:54
If you have all the parts you an swap back and forth to make everything bolt up. The correct police will give you a ticket.
steve
03-05-2002 19:33:16
I saw a B last summer with a 4 speed just as you mentioned. It had a narrow rear end, meaning the final drives were off a B. There are internal differences, but i believe as units, you can interchange the engines, transmissions and final drives on the B,C, and CA
