WD 45 value
Harold
03-04-2002 06:59:38
What is a WD45 with narrow front above average mechanically, with good tin worth? Are they more popular in some places in the country than others. And what are the weak spots on them. I want to use just the drawbar and not snapcoupler for field work. Thanks Harold
James (MO)
03-05-2002 05:29:02
 Re: WD 45 value in reply to Harold, 03-04-2002 06:59:38
I know it's off the subject, but be sure it's a WD-45! 75 percent of the "WD's" in Southwest Missouri have WD-45 decals and the seller will swear it is a 45. my $0.02
LazyHorse
03-04-2002 09:07:17
i live In east central Indiana, and at auction they go for anywhere from $800 to $2500 depending on condition. The only problem i see with the older AC's is they tend to pop out of gear if they are worn very badly, but the WD and WD 45 are good machines.
Tom
03-04-2002 18:05:22
 Re: Re: WD 45 value in reply to LazyHorse, 03-04-2002 09:07:17
And you want to keep a good boot on the shift lever to keep water out of the transmission. While not really a weekness with ACs it is something that can cause damage to the transmission, PTO, and rear end if water gets in and freezes, and this ishow it gets in.
