Allis Chalmers C wiring question
Lee Boland
03-01-2002 06:49:32
I'm restoring an Allis Chalmers C that had been
retrofited to a 12 volt system. The restoration
includes putting it back to a 6 volt
configuration. It appears the ground cable to the
frame must go to the negative pole of the battery
and the positive to the starter terminal however I
can't find any confirmation of that in the books I
have. Any comment? Thanks.
Jim Guarino, Agri-Services 716-937-6618
03-08-2002 03:31:41
 Re: Allis Chalmers C wiring question in reply to Lee Boland, 03-01-2002 06:49:32
We make original type cloth covered wiring harnesses for farm tractors. The AC model B,C,CA harness set is priced at $99 + $6 USA shipping. This includes wiring to the lamp housings, and other individual leads. We also have the 3 position light switch, mechanical cutout relay, cloth covered battery cables, spark plug wires, ignition switches, fuse holders, starter relays and other switches. All of our harnesses are labled, and include a connection sheet. See our web site for a listing of prices and applications.
Steve in N.J.
03-01-2002 10:22:00
Lee,
If you need a harness for your C, or help with the wiring drop me an e-mail. Be happy to help ya out....
Dick L
03-01-2002 07:03:08
The 6 volt system has a positive ground.
Take a look at the drawing enclosed.
Click PREV for mor info
Don Holden
03-01-2002 20:20:58
 Re: Re: Allis Chalmers C wiring question in reply to Dick L, 03-01-2002 07:03:08
Dick, that schematic for the C is super! Would you happen to have a similar drawing for a 61 Gas D17. Serial# 33383. I plan to do a little clean up and that will help me keep everything straight after I get the sweetheart shiney. Thanks in advance.
Don
Dick L -- OK Don
03-02-2002 06:35:20
 Re: Re: Re: Allis Chalmers C wiring question in reply to Don Holden, 03-01-2002 20:20:58
The first one is for the early D 17 and if you click on NEXT you will find one fer the later D 17
These are not as crisp as the CA diagram from above. If you have some photo software you can blow it up and print it a little larger.
No real difference between the B, C, and CA diagrams except for the pull starter rod in the picture.
mike shope
04-13-2002 18:20:57
 Re: Re: Re: Re: Allis Chalmers C wiring question in reply to Dick L -- OK Don, 03-02-2002 06:35:20
Looking for diagram and the how to on changing an AC-D-17 from a generator to an alternator.
Don Holden
03-02-2002 17:24:31
Dick, Thanks for the wiring diagram! I don't have the photo software but the printer did a good enough job that I can make everything out. I appreciate the help!
Don
steve
03-01-2002 16:28:21
I assume if you are going back to 6 volt, you have an original generator that is positive ground you will be using a cutout relay and resistor light switch??
