Will E-3 engine fit in a WD or WD-45
Willie
02-28-2002 16:44:11
I have been told that the e-3 combine engine will bolt right in a d-17, I'd like to know if it will fit in a Wd or Wd-45. If so, this would be a economical way to get this one going. Thanks a lot, Willie
Alan
03-03-2002 17:51:50
 Re: Will E-3 engine fit in a WD or WD-45 in reply to Willie, 02-28-2002 16:44:11
My father put an e motor in his 56 wd-45.I'll ask him the low down and get back to you.
Willie
03-04-2002 00:03:13
 Re: Re: Will E-3 engine fit in a WD or WD-45 in reply to Alan, 03-03-2002 17:51:50
Thanks, I'll be looking forward to hearing about it. Thanks, Willie
Alan
03-04-2002 08:22:10
 Re: Re: Re: Will E-3 engine fit in a WD or WD-45 in reply to Willie, 03-04-2002 00:03:13
Willie,
If the motor in the E3 is the same as the older E then it will bolt in.You will need to change the front crank pulley back to the wd-45.The E/D-17 motor has a different set-up for the water hoses so the pulley needs to be changed.You will need to drill a hole in the pulley so it can be locked on the crank.Afew oil lines will need to be moved where the steering rod passes the motor.(My fathers has power steering)Put a plate over the fuel pump hole.The backing plate will bolt up.I'm sure there are some small things that will need to be done but thats what he told me he did. Good luck,Alan
