Model C distributor lubrication
Dana
02-27-2002 20:34:57
Hey guys, how does the distributor gear get lubricated? There doesn't appear to be an oil galley. Do I grease the gears or fill the housing with oil?
Also, the horizontal shaft that runs from the distributor to the governor has an access plug which I assume is for oiling. What type of oil should be used? I've checked my IT manual, as well as my Service manual and Operator manual and I can't find anything that addresses either of these questions.
steve
02-28-2002 19:09:44
 Re: Model C distributor lubrication in reply to Dana, 02-27-2002 20:34:57
the oil pump in the back pumps down a hollow cam shaft. there is a spray plate at the front of the cam, on the steel cover plate that throws oil coming out of the cam shaft all over the front gear train.
steve
02-28-2002 19:09:18
