Power steering fluid for D-19
steve
02-26-2002 09:15:58
The service manual for my gas D-19 calls for type A automatic transmission fluid to be used in the power steering system. I cannot locate this in my area. What would be a suitable replacement for this?
steve
02-26-2002 19:02:16
 Re: power steering fluid for D-19 in reply to steve, 02-26-2002 09:15:58
Mercon (ford) or Dextron (GM) would be o.k. and mix directly with the old. If the oil has been in there a while i would drain it out and refill. You can even use hydraulic fluid if you prefer. The steering system is not that particular. Just standardize on something and stick with it. I use Mercon in the D17 for years, because i have it for the ford truck.
