Re: ACB rotor pinion / distributor gear + moisture
Scott ks
02-25-2002 17:07:00
In response to your moisture problem. On some distributors there is a vent to outside air so the distributor can "breath" so the temp can be about the same on inside and outside. Make sure you do not stop the hole up. Kinda like the balloon in the sunshine.
HTH.
Scott ks
