Wd45 llift arm cilinders?
bill a
02-25-2002 01:31:50
have 45 with leaking lift arm cilinders.tractor stored outside before igot it;rams are pitted on ends.wunder'n if is worth while putt'n in new seals or just get new rams.i'am green when come to hydrolics so any sugest'ns wud be appreciated thanks bill
Tom
02-25-2002 18:01:47
 Re: wd45 llift arm cilinders? in reply to bill a, 02-25-2002 01:31:50
Bill,
If the chrome is off of the cylinders and they are pitted, they will leak after you replace the seals. These cylinders should be available from any salvage yard that has an inventory of WD's or WD45's, and they can ship reasonably because they are not very heavy. When you receive the used ones that are not pitted, replace the seals before installing on the tractor and you will be pleased with the results. Tom
