PTO shaft for C
Danny Chamness
02-24-2002 18:52:13
I would like to replace the PTO shaft in my C with a larger diameter and the notch for quick connect implements. I have used the adapters but they seem to break rather quickly. Any Ideas?
David A. Laughead Jr.
02-26-2002 16:23:22
 Re: PTO shaft for C in reply to Danny Chamness, 02-24-2002 18:52:13
Just a thought, but, What about one of those PTO overrun coupler/clutch. You should be able to get on that is 1 1/8 to 1 3/8. You would need one anyway when driving a brush hog or similar implement.
Hope this helps,
Dave Laughead
Danny Chamness
02-27-2002 16:59:04
 Re: Re: PTO shaft for C in reply to David A. Laughead Jr., 02-26-2002 16:23:22
I had considered an overrunning clutch, and you are right I will need one, but the PTO shaft in my tractor seems to have been drilled in the wrong spot for most implements and connectors I have found. I could drill another hole but was afraid that would weaken the shaft too much.
Thanks Dan
