Wd45 runs backwards
Ed G
02-19-2002 14:19:52
I have a wd-45 and it runs good for a short time then stalls and runs backwards any help with the problem?? thanks
Ryan-IN
02-19-2002 17:18:16
 Re: wd45 runs backwards in reply to Ed G, 02-19-2002 14:19:52
Had the same thing on my d17 when I would shut it off, timing gear was off one tooth. Pulled the gov. assembly and lined it up proper, and it ran MUCH better, and no dieseling at shutdown.
Duey (IA)
02-19-2002 14:46:07
Ed,
I assume by running backwards, you mean a few rpms after it dies. Sounds like a fuel problem or possibly the timing may be off . Checking the fuel flow from the fuel line at the carb would be a starting point.. If it slows or stops, the fuel sediment bowl inlet hole could be partly plugged. New points and condensor with the proper timing would be the next step if the fuel is OK. Duey
Ed
02-19-2002 18:28:08
 Re: Re: wd45 runs backwards in reply to Duey (IA), 02-19-2002 14:46:07
Duey, the wd45 when running , looses power then stops and runs backwards after it dies and fires back though the carb , thanks again for your help Ed
Duey (IA)
02-19-2002 19:50:35
 Re: Re: Re: wd45 runs backwards in reply to Ed , 02-19-2002 18:28:08
Ed,
Sounds like it's running out of fuel. Check the fuel flow. If it starts again after a few minutes, the fuel could be just about shut off. If it shuts down and has no spark, then look at the condensor or coil. Firing back through the carb would indicate the spark could be OK just lean on fuel. Do some checking then let us know what you find. Duey
