What size plow for WD45???
jason
02-18-2002 18:50:50
What size plow can I mount on my tractor and use it without overworking it? A 2, 3, or even a 4 bottom plow?
Jon,NH
02-24-2002 03:22:10
 Re: what size plow for WD45??? in reply to jason, 02-18-2002 18:50:50
I have a double bottom landplow with a snap coupler set up for WD45,i think that be all you would want to go,thats a good size landplow....plus the plows i have are a roll over setup.Just the weight alone is a lot.
Ron
02-18-2002 19:32:49
3-14" Mounted is hardly a load for a WD-45...
If ya have good tires, and all tires loaded, go for the 4-14" semi-mounted....in nearly any soil, it will run in 2nd gear..once it is scoured up.. You will use a lot less gas per acre... Muffler stands 12" of Blue flame, and turns Red..!!!! Plow without any lights..!!
