Stickers for a 48B
Pete
02-18-2002 14:08:56
I already posted this but I am desperate!
can anyone tell me where the stickers go on my 48B
I dont want to cock it up and would really appreciate the help
Unimog
02-18-2002 17:01:21
 Re: stickers for a 48B in reply to Pete, 02-18-2002 14:08:56
I have a decal set AC 213321 which is for a later
model B. I can help you with a few decals to get
you started. The bonnet ones should have a long A
and S and should be easy to place. The wiring one
goes on the underside of the battery box lid. A
small one Drain Here and at Radiator goes under
the block drain tube where it will not be hit with
water from drain. Air cleaner decal goes on the
upper body about 2" down from the top looking slightly to the rear. The "B" decal does not go
on your tractor,they were used starting with the
1950-51 models. The radiator shutter decal goes
a little below the handle toward the rear. The
Change Filter every 100 Hours goes on the oil
filter base just below the screw-on filter. The
other decals I would have to guess on their lo-
cation. All of these are optional as it's your
tractor and their use is your decision. Use the
ones you like and forget the others, it won't
ruin the job you've done. Hope this helps you with
your tractor.
Unimog
