Re: Question on D14 Valve Clearance Final Drive on Allis Chalmers C
steve
02-17-2002 14:51:54
I set the valve clearance at .010 hot or .012 when cold. The cover on the final drive covers the end bearing where clearance is shimmed. YOu should see a bolt in the end of the shaft. The cover should have a bead or RTV and pound into the hole. No grease, it is lubed with 80-90 wt final drive oil. DIdnt some come out when the cover came off?. Might want to check the final drive level thru the 1/2 inch pipe plug in the sheetmetal pan. The bull gear runs in the oil and splashes it up to the top gears and bearings.
