Re: HOW TO ENGAGE BELT PULLEY
Ron
02-15-2002 05:12:39
To engage the pulley....
With engine shut OFF...loosen the set-screw bolt on the side, near the frame, behind the pulley.....Slide the whole unit toward the frame, try to rotate the pulley to see that the gears are meshed.... Tighten the set-screw bolt, and you are done.. The unit is in far enough when the set-screw bolt turns in...tighten it good....
