Stuck WD
Glenn S. Decker
02-14-2002 22:43:27
I've been working on a WD a friend gave me last week. Same old story- " it was runnin' last year ( or was it 5 years ago )". Anyway, I've been soaking and flushing the cylinders with kerosene; got some water and rust chips out of 3rd and 4th cylinders, but she's still stuck tight. Anyone used anything they think works well to break loose a stuck engine? Thanks, Glenn
Dennis Reno
02-15-2002 18:11:32
 Re: Stuck WD in reply to Glenn S. Deckert, 02-14-2002 22:43:27
I have a WD45 that sat out side for seven years. It was super stuck. I used a penetrating oil called FREE by Certified Laboratories. It is similar to Kroil if you can find that. Most aerosol penetrating oils will evaporate, so I would douse the cylinder every day for a week. I would also replace the spark plugs each time. At this point I pulled out the plugs and put her in neutral. Chock the wheels and take the starter off. The next part sounds a little wierd, but it works. I took an old tire iron with the flat blade end, and cut the socket end off. I then slipped a four foot section of pipe over the end of the tire iron. (This should be welded together for safety) Carefully place the blade end down as far as you can get on the flywheel. The very last tooth showing. It doesn't matter which side. Pull down on the bar with every thing you have. At this point, my flywheel moved about two or three teeth. I then went to the other side of the flywheel. I did the same thing. It moved back to the stuck spot easily, and then got stubborn again. One more real hard pull and it went half way around. At this point, I soaked the cylinders again, this time with oil. You will be freed up most of the way around until you hit the spot where it was froze up. Just keep working with it. The rusted places in the cylinders just need to be worn down. This method sounds danderous, but it works. You can get a lot more leverage at the flywheel. Take your time, and try not to slip off the tooth. This is a last resort when rocking in high gear won't budge it. This really does work, my WD45 runs great.
Ron
02-15-2002 05:21:36
If you see rust chips, trying to turn it over without cleaning the cylinders will just ruin the rings.... But, if you MUST....Marvel Mystery oil with Kerosene or any GOOD penetrating oil in the cylinders---Let Set---may take days.... Put tractor in High gear, and rock back and forth... Putting hot water ( not too Hot.!!) in the block will help --May need to repeat several times... Be sure to leave the sparkplugs OUT..!!
