Rims and tire sizes for wd for pulling?
scott brown
02-14-2002 17:09:32
i have 8 bolt rims on it know there stock with the spin out rims i want to put bigger tires on it and need rims to fit so i can put 38 in rubber on it for pulling in antique class what will fit this tractor wd45? need help thanks scott
Forgot
02-15-2002 16:23:40
 Re: rims and tire sizes for wd for pulling? in reply to scott brown, 02-14-2002 17:09:32
You have to use your stock wheel centers or get a couple from somebody like a salvage yard. LL.
LL
02-15-2002 16:15:04
Get some duals at action and build them. Takes time, a tape measure, a welder, a level, a flat pad of cement and good eyeballing but can be done. First set I built took 6 hours and I knew very little of what I was doing but they turned out without a wobble.
