Company Logo (800) 853-2651 Shop Now
Re: Restoring my Pop's AC-WD and really need help...
Ron
02-11-2002 21:29:30
When you find #1 TDC Compression.....no matter which post the button is pointing at is going to be #1 on the cap---you see, the Distributor may not be installed in the original position, and THAT does not matter... Then install the rest of the plug wires in order, in the cap...
Rooster
02-12-2002 08:06:13
 Re: Re: Restoring my Pop's AC-WD and really need help... in reply to Ron, 02-11-2002 21:29:30
Couldn't i rotate it till it lines up with the 1 marked #1?? Or just remark them in the order duey gave me??
Ron
02-12-2002 10:59:04
 Re: Re: Re: Restoring my Pop's AC-WD and really need help... in reply to Rooster, 02-12-2002 08:06:13
Ideally everything could be perfect--BUT..!!!
It may mean taking the distrbutor out, and re-setting it's position---a good chance you will have trouble getting it ALL fouled up...!!! Just find the one that is pointed at, when you find #1 TDC, and use it as #1..... No use making it harder than it has to be..!!
Rooster
02-12-2002 16:01:22
 Re: Re: Re: Re: Restoring my Pop's AC-WD and really need help... in reply to Ron, 02-12-2002 10:59:04
I agree, I was only asking because th cap was off of it when i got to it. It was all there, just apart. Thank you
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 706 gas fuel tank&radiator [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
