Oil seal numbers wanted for BC
Dave D
02-11-2002 15:23:32
Does any body know what the numbers are for the oil seals for the front axles for a C, also the oil seal numbers for the shaft that goes up inside the houseing,[pedestal] both top and bottom ones? On the -B- rear end I'm looking for the numbers of the seals for the final drive shaft, both of them [one goes inside the houseing that bolts to the rear end, and the other goes on the final drive shaft between the brake and the bearing].Thank You
Steve in N.J.
02-14-2002 21:40:01
 Re: oil seal numbers wanted for BC in reply to Dave D, 02-11-2002 15:23:32
Dave,
My Napa/CR seal book lists the final drive seals but not clear on the pedistal. Here's the final drive seal numbers for B,C,1B: Inner-11801 Outer-13900
They list in the book "Steering/Dual wheel" seal # 17605. Maybe this is the pedistal seal? Hope this helps you out....
Dana
02-16-2002 19:53:58
 Re: Re: oil seal numbers wanted for BC in reply to Steve in N.J., 02-14-2002 21:40:01
Dave - I'm planning on tearing down my C's tricycle front-end sometime during this next week or so. If I manage to figure out what seals fit this, I'll let you know. You do the same in return if you happen to figure them out before I do! (I had checked at the local NAPA last week and they told me the same thing Steve says.)
