How do I tell if it's a B or C?
Jerry Kirkpatri
02-02-1999 18:22:50
I've come across a real find and the price seems more than reasonable. The seller says it's either an AC B or C. How can I tell for sure?
Gary
02-02-1999 19:08:03
 Re: How do I tell if it's a B or C? in reply to Jerry Kirkpatrick, 02-02-1999 18:22:50
Serial numbers for "B" and "C" is stamped
on transmission just ahead of shifter lever.
"B" serial starts with a B , "C" serial starts with a C .Most "C" were either narrow front or adjustable front axle . "C" rear axle hubbs are longer on a "C". (more space between the rear tire and fender ) plus there are 2 threaded holes in this casting for attaching implement brackets.
"C" rear wheel rims attach to axle with 6 or 8 bolts , "B" rear rim attaches with one large nut in centre of rim.
Hope this helps.
Gary
Jerry Kirkpatrick
02-02-1999 19:23:52
 Re: Re: How do I tell if it's a B or C? in reply to Gary, 02-02-1999 19:08:03
Thanks, Gary. I'll check it out this weekend and let you know what it is.
