Re: Sleeves sitting up!
peter
02-10-2002 23:44:20
that should read block has been planed...not the head...cus it is not even on at the mo.!
thanks guys
Ron
02-11-2002 21:16:20
 Re: Re: Sleeves sitting up! in reply to peter, 02-10-2002 23:44:20
Before you drop the sleeves in, put a good heavy coat of Aviation gasket sealer all around the "O"ring area... Coat the web between the sleeves, too... Then you will NOT have any problems with leaks--Even if the block cracks a web ( between the sleeves)... "Old Timers" used to say to use paint from the bottom of the can--the Thick stuff...enough to cover the bottom of the water jacket... I know that "AC" blocks can get a crack in the bottom web..ya might as well "be sure"....!!!!
