Company Logo (800) 853-2651 Shop Now
Re: My AC B
steve
02-10-2002 19:09:45
we will assume you have a distributor and not a magneto. You should have a coil next to the distributor. one side of coil connects to the tractor frame. the other side goes to the battery terminal (or thru the toggle switch to the battery.) on the terminal that is not grounded to the frame. if you have "power to the distributor" i am assuming you mean the coil is hot. the coil wire (big black) goes to the center of the distributor. the 4 plug wires come off the radius of the distributor. put a spark plug in one of the wires and touch the plug to the engine block. crank the engine and look for a spark. if no spark, you need to remove the distributor cap and clean the points. this assumes the coil is good. you can put one spark plug in the coil wire to the distributor, and touch the power wire to the coil small terminal on an off and watch the spark plug spark. if it dont, the coil is bad, or not wired up right.
Today's Featured Article - Identifying Tractor Smells - by Curtis Von Fange. We are continuing our series on learning to talk the language of our tractor. Since we can’t actually talk to our tractors, though some of the older sect of farmers might disagree, we use our five physical senses to observe and construe what our iron age friends are trying to tell us. We have already talked about some of the colors the unit might leave as clues to its well-being. Now we are going to use our noses to diagnose particular smells. ELECTRICAL SMELLS ... [Read Article]
Latest Ad: JD factory 3pt hitch fits 2 cyl 20 and 30 series tractor and 2 JD rear wts for late 2cyl and new gen Price 2000 for pkg calls only [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
