180 gas run problem or electrical problem
Dean
02-08-2002 18:23:29
I have a gas 180 that I put new plug wires, plugs, points and condenser and distributor cap. Put carb. kit in and new gas filter. Starts but as soon as I put it in gear and take of it pops and sputters and dies.
Gordon-(TN)
02-12-2002 01:23:24
 Re: 180 gas run problem or electrical problem in reply to Dean, 02-08-2002 18:23:29
Some things to check would be the fireing order, to make sure the wires are on the right plugs, is a wire going to ground in the dist, is the wires tight at all off the conections, is the coil wire seated in cap & coil good, there was point sets made with two straps & a slot to slide over the bolt where the condenser bolts on, if any part of this gets to ground and arks fire it will cause a problem
hope this helps good luck
Gordon
