Model B clutch
Craig
02-07-2002 21:05:24
Have the clutch out and would like some thoughts on using the old or getting new. The disk is .300" thick, and has no scars on it. The throw-out bearing spins freely, but has slop, like a wheel bearing that's not tight enough. The leavers that the throw-out bearing makes contact with have about 1/4" wide wear area, two are .100" thick and one is about .060" thick within the .250" wear area.
Dick L
02-08-2002 11:01:42
 Re: Model B clutch in reply to Craig, 02-07-2002 21:05:24
The ware on the pressure plate levers shows you have more drag on the throwout bearing than you want, even though it turns freely without pressure on the bearing.
