Oil presure wd45
bill a
02-07-2002 03:42:19
ihave wd45 not sure if it has enough oil presure.gauge reads around 20psi.if any one knows what presure shood be, would be much appreciated thanks bill
dave K
02-09-2002 14:56:21
 Re: oil presure wd45 in reply to bill a, 02-07-2002 03:42:19
The WD's all ran about 8 to 12 pounds pressure measured at the AC gage on the oil filter housing. This is a by-pass system so you are reading what is getting through the filter, not what is actually in the engine itself. If you use the correct filter, and be certain the center pipe goes up through the filter, then you should read around the center of the gage at high RPM, a lot lower at idle.
Dave
Dave Grubb
02-07-2002 06:45:41
You are above normal if you are sure your gage is indicating accurately. The tractors usually run 9 to 12psi. Someone may have shimmed the oil pressure relief valve a little. A tractor with the AC gage should have pressure indicating on the 'o','r', or 'm' according to the operators manual. I have checked the indications of my AC gage at the 'o','r', and 'm' indications and they are 3, 6, and 9 psi respectively. For best results use a gage wherein the center 50% of the gage span is used to provide the indications you are concerned with.
bill annett
02-07-2002 13:26:15
 Re: Re: oil presure wd45 in reply to Dave Grubb, 02-07-2002 06:45:41
Thanks for the information, Dave. Pressure guage on my tractor isn't an AC guage, it goes from 0 to 100 psi. I just fired it up and it's pretty close to 12 psi. I guess I should buy a real AC guage. Thanks, Bill.
