D-14 pushing snow
Grant
02-03-2002 19:40:26
I've got a problem with my A-C D-14. I mounted a 12 foot dozer blade on the 3pt hitch. when I'm pushing snow it sometime boggs down a bit. Is this a little too much work for this tractor?
Jim in NW Mich
02-04-2002 19:10:06
 Re: D-14 pushing snow in reply to Grant , 02-03-2002 19:40:26
I have a front loader for my D-14 with a 6 ft snowplow that can be substituted for the trip bucket. The plow stands about 24-30 inches high. Even with loaded tires, tire chains, and wheel weights, a full blade of snow is about all I can handle without digging holes in the driveway or yard. I do not seem to lack for power, as I can easily push it at lower rpm's in 2nd or 3rd gear, high range. I seem to be limited only by the available weight on the rear tires to provide adequate traction, no matter what type of snow we have.
steve
02-04-2002 16:20:41
that has to be a sight backing into a snow pile. We used a 8 foot on a D17 and it works great. I think a 7 or maybe 8 ft would be plenty, unless you are pushing powder.
GeneD14
02-04-2002 12:00:36
A 12 foot blade sounds a little big for heavy snow. I use a heavy duty 7' rear blade with tire chains on and wheel weights and my D14 does great.
JMS/MN
02-03-2002 21:54:21
How deep is the snow, and how wet is it? In Mn we wouldn't even think of a 12 foot blade on a tractor that small. Width of the tractor might be all it can handle, and then it depends on how severe the blizzard was. In northern states we get a lot of dry snowstorms- low water content, and we can push a lot, but our March storms are wetter, and it takes power to move that- same thing with snowblowers. I use the snowblower as long as possible- seven foot on 125HP, and for a late spring storm, might use the seven foot bucket up front with a 1500 pound bale on the three-point bale fork for traction- now THAT pushes snow!
Ric McDougal
02-03-2002 19:47:28
well there are a couple things wich could be wrong. first thing that could be wrog it that your tractor might need a chrome stack that could improve your proformance cuz a D-14 should be able to push a larger blade with eas. another problem could be your tires if they have to much traction they could be resisting to much cauzing your motor to die. well good luck i hope i helped u a bit. but it should be able to push it.
R. McDougal
