WC Cultivator
Larry
01-30-2002 09:41:10
I have a styled WC with front mounted cultivator and mechanical lift. My question is "Did the cultivator come with a rear section to cover the tire tracks?" There is a pipe across the back with a cast bracket on each end. The bracket appears to be to hold another pipe at 90 degrees to the crosswise pipe. Any pictures would be very appreciated.
Joe M
01-30-2002 16:22:16
 Re: WC Cultivator in reply to Larry, 01-30-2002 09:41:10
I sent you a couple of pics I found of the rear set.
JMS/MN
01-30-2002 17:13:52
 Re: Re: WC Cultivator in reply to Joe M, 01-30-2002 16:22:16
The WC cultivator did have rear gangs, a couple of teeth mounted on L-shaped pipes that were a pain to mount, so we usually cultivated without them. They just covered the rear wheel tracks. I missed out on a WC cult that went to the scrap yard a month ago; would have bought it, even tho my Allis's are WD and WD45, since I'm working on a couple prospects with RC models, and the WC cult should fit that tractor.
Larry
01-31-2002 04:43:26
 Re: Re: Re: WC Cultivator in reply to JMS/MN, 01-30-2002 17:13:52
Thanks for the info (all of you). I missed a nicer set just like mine (no rears too) get sold at a boneyard auction a couple weeks ago...would like to see what they brought...probably no bid, the owner said a fairly complete F20 skeleton only brought $1...man, was I on the wrong side of the field!
Tom W.
01-30-2002 11:47:07
Larry,
I have talked with several people that use to use the WC culivator and they use to have a rear secton. I guess they were not very good. They use to take them off and throw them away. I have not been able to find a complete cultivator for a WC anywhere.
Steve (Wi)
01-30-2002 14:08:10
 Re: Re: WC Cultivator in reply to Tom W., 01-30-2002 11:47:07
I know where there is a complete set-up for a WC in very good condition for sale. E-mail me if interested. Central Wisconsin.
Steve
Tom W.
02-01-2002 09:35:22
 Re: Re: Re: WC Cultivator in reply to Steve (Wi), 01-30-2002 14:08:10
I think I should pass on it. I should be able to find one closer to KS. Thanks for the offer.
