B Kill switch
Tom in Tacoma
01-29-2002 17:51:24
Can anyone tell me how to wire in a kill switch on my 39-B that has no ignition? I haven't had this running since I brought it home a year ago and I think I stalled it back then.
Tom
Dick L
01-29-2002 20:40:28
 Re: B Kill switch in reply to Tom in Tacoma, 01-29-2002 17:51:24
This might give you and idea
steve
01-29-2002 19:02:13
I think you mean it has a magneto ignition. No battery, coil or distributor right? The magnito is at the front right side of the motor. about the center of the aluminum housing you will see a small threaded terminal about the size of pencil lead. If you short this terminal to the tractor frame the motor will stop, ignition shorted out (spark grounded).What you need is a toggle switch mounted by the steering column that has one side grounded to the frame and the other terminal on the switch connected to the small terminal on the magneto. You just need to remember which direction is Off and which is ON.
Tom in Tacoma
01-29-2002 23:26:05
 Re: Re: B Kill switch in reply to steve, 01-29-2002 19:02:13
Thanks Steve. I think I have it now. You are right, I do have a mag.
Tom
Ronnie in Fla.
02-11-2002 21:04:24
 Re: Re: Re: B Kill switch in reply to Tom in Tacoma, 01-29-2002 23:26:05
I had the same problem, and since I have a 9 year old that likes to drive the "B", I ran a wire from the magneto to a horn button that just fit just above the ammeter box, and grounded the other side. This shuts the tractor down, and I don't have to remember to turn the switch back on to crank.
