D14 Cranks sloooooooow
OHD14
01-26-2002 19:21:39
This fall my D14 started turning over very slowly when started for the first time each day. At first wasn't to much of a problem, but has gotten worse. I thought my battery was going down. Today I replaced the battery, but no change. Still wants to turn real slow when first starting. After it gets started for the first time runs great and starts good the rest of the day. Any thoughts or input would be helpful.
Thanks in advance
steve
01-26-2002 19:36:12
 Re: D14 Cranks sloooooooow in reply to OHD14, 01-26-2002 19:21:39
i would remove all the battery cables to starter and battery and clean the ends. if any wires bulged or corroded, replace them. you could chekc the voltage at the starter when cranking, if you have a volt meter. common to have loss of voltage due to bad cables on these old tractors.
DJ
01-27-2002 17:04:48
 Re: Re: D14 Cranks sloooooooow in reply to steve, 01-26-2002 19:36:12
If cables don't help take your starter to someone who rebuilds them and have it checked. It could be bad or just need brushes. I've seen that a lot.
