D-17 diesel
Larry V
01-25-2002 07:09:56
Can anyone tell me if the return line (on a D-17 diesel engine) from the injector has an "O ring" seal or is it a flair fitting? I have one that is leaking and tightening does'nt seem to help.
jim long
01-29-2002 10:12:04
 Re: D-17 diesel in reply to Larry V, 01-25-2002 07:09:56
all lines to injecters, return lineshave a rubber like seal. more like a tapered faucet washer
Larry V
01-26-2002 17:08:12
Thanks for the information. I'll probably go ahead and replace them.
D-17 Dave
01-25-2002 18:11:46
The return lines you are refering to are sealed with O rings with squared off corners like a piece of tubing cut. After a few tightnings they deform and will no longer seal. New ones are readily availiable from AGCO but the fer-shure fix is as Denny discribed by replaceing the preformed, welded line with compresion fittings and tees. A little cubersome to mess with at first with all the little lines, but you probably won't have to mess with it again.
Denny
01-25-2002 14:31:00
Larry, these lines came from Allis sealed by rings that were square in cross section. Tightening the nuts will sometimes help. On mine, I discovered that Allis did not use seamless tubing so thecross section of the tube ended up looking like a notch at every return connection. I bought new seals but they didn't solve it. So finally I had to replace all of the tubing. I used soft copper so my lines aren't as straight as the original but they don't leak. For the tees, I used compression fittings designed for soft copper. It was a pretty inexpensive fix. Email if you have more questions.
JMS/MN
01-25-2002 10:56:09
Just noticed your post referred to the return line, not the pressure line, so perhaps a cracked line is not likely to be the source of the leak.
JMS/MN
01-25-2002 10:52:20
I don't know the answer to your question, but I would also check the line itself, for a miniscule crack where it attaches to the injector. I've had leaks on JD and Case tractors that sound like yours, but the line itself was cracked. The weld along the line can crack loose from vibration, especially if those little brackets clamping two lines together are missing.
