Disk for a d-14
Doug
01-22-2002 16:13:27
I just got a d-14 and was wondering about how wide of a disk I should be able to use with it.
Thanks
GeneD14
01-23-2002 04:58:33
 Re: disk for a d-14 in reply to Doug, 01-22-2002 16:13:27
I have used a six foot disk with weights on it behind my D14 and it was hard to tell that it was even behind the tractor. I would think that an eight foot wide disk would be a better match. If the disk is mounted you may need some weight on the front end of the tractor when you lift the disk up.
Brian B (MO)
01-30-2002 18:23:02
 Re: Re: disk for a d-14 in reply to GeneD14, 01-23-2002 04:58:33
Gene is right. I tried to pull a 10 ft wheel disk, and it did pull it, but it was all that it wanted. I would have hated to hit a wet spot too. 8' is probably ideal
