CA serial number
Tractor Rod
01-20-2002 10:15:35
I have a CA cane tractor and was wondering where on the tractor I might find the serial number. As you sit on the tractor to the left of the shifter is casted tractor number with a blank under it but nothing is stamped in there.Any help,thoughts or ideas would be appreciated. Thanks Tractor Rod
steve
01-20-2002 19:17:09
 Re: CA serial number in reply to Tractor Rod, 01-20-2002 10:15:35
If you are sure there is no number stamped (and coverd by paint), then the transmission failed in years past and was changed out with a new unit which had no number. If this is the case you can look at the engine behind the distributor. should be cast AM2916 - xx the two digits at the end will tell you the approx year manufactured. 1938 is 10, 1939 is 11, etc, 1958 would be 30.
wu
09-10-2003 19:48:34
 Re: Re: CA serial number in reply to steve, 01-20-2002 19:17:09
What's your source/reference for dating the casting? Just a good theory?
