WD 3 Point
Rod
01-20-2002 05:17:41
My 3 point lifts, but will not drop even after the tractor is shut down. Where do I start.....with a new hydralic pump or can it be rebuilt without a ton of special tools
David T (MO)
01-21-2002 06:07:28
 Re: WD 3 Point in reply to Rod, 01-20-2002 05:17:41
Two things could be happening.
The first and easiest to check is the traction boost control knob labeld "A" on your battery box decal. This is on the large plate located near the bottom of the pump. The plate should be rotated against the spring (counterclockwise I think) and the knob screwed into the pump body detent (be sure to clean the dirt out of the detent). Many times this knob vibrates out of the detent (and maybe out of the plate completely) and if you don't have the traction boost linkages adjust properly (or they are missing completely) the pump will go into full lift and ignore the manual controls.
The second possibility is in the pump itself. The pump is positive control to lift (a cam pushes the control valves towards the front of the pump) but the pump relies on a small spring to push the control valve back against the cam when it is rotated to the drop position. If there is any grit in the control valve chambers the valves can stick in the lift position. Another possibility, although less likely, is that the oil return chambers that allow the oil in the rams to return back to the reservoir (also internal to the pump) are completely blocked.
Check knob "A" first and then get back with us for further details on removing and disassembling the pump.
Dave in Mo
01-21-2002 04:54:01
Sounds like you may need a linkage adjustment. I don't have my copy of the manual handy, but get one (from Norm's Toys or maybe Sandy Lake Implement) or the like for about 20 bucks.
Don, Luling LA
01-20-2002 16:06:15
I am also not a hydralic expert but it seems that it your 3-point lifts but doesn't go back down it might be something in your lift control system rather than your hydralic pump. Because if it lifts then I would think your pump is a pumping.
Jamie
01-20-2002 08:43:37
I am not the expert, however I had the same problem with my loader on my WD. With help from this board I was able to take the pump apart, clean it up, put in new springs and got it to work. No special tools needed. After reading in repair manual pages that some one had emailed me and understood how it worked made it a lot easier. Good Luck. Jamie By the way I believe i9f I can do it anyone can.
