CA Fluids
Mike
01-18-2002 19:53:33
I have a 51-52 CA and I know nothing about tractors. I would like to find our what fluids are used in the various sections, such as:
tranny and hydraulics - I got some lubricant for this and it says it replaces Power Fluid 821.
Is this the right lubricant and does it go into the dip stick hole, in front of the seat on the left side. Or is that another fluid. To replace the seals, are there kits available, or do you have to figure out which part is leaking and hope to find the right seal.
Rear end - What is used and where is it filled?
Trike front end - What lubricant and where does it go.
Motor oil - what weight
I have a manual. however, it talks parts not fluids
Thanks for you help.
Mike
steve
01-18-2002 20:19:03
 Re: CA Fluids in reply to Mike, 01-18-2002 19:53:33
we put 10w-30 oil in the motor.
we buy hydra- trans fluid at Wal Mart for the transmission-hydraulics-pto. 3 drain plugs on the bottom, one fill by left foot. the final drives are fiied thru the 1/2 inch pipe plug on the pan, we used 80-90wt. you have to remove the pan to drain it. you can put them back on with RTV as a gasket.
Mike
01-20-2002 07:22:45
 Re: Re: CA Fluids in reply to steve, 01-18-2002 20:19:03
Thanks for the info. My shop manual talks about parts, not fluids.
Does the Trike front end use 80-90W as well?
Thanks again, Mike
steve
01-20-2002 19:38:22
 Re: Re: Re: CA Fluids in reply to Mike , 01-20-2002 07:22:45
80-90wt is fine. Depending on where you live, if you want 140wt- o.k.
Mike
01-21-2002 08:07:33
 Re: Re: Re: Re: CA Fluids in reply to steve, 01-20-2002 19:38:22
I live in NE Oklahoma. Would 140 not lubricate as well when cold? Probably 90 W is best.
Thanks Mike
Paul
01-18-2002 20:06:55
The trans, differental , Hydrulics and Pto all use common fluid checked at dipstick you described on transmission housing. AC recomends 20W/20 non foming , I have had good luck with generic HyTran Fluid , AC's blend would be the powerfluid 821. Final drives check at plug on side of cover, 140 weight seals only come individually.If you have an operators manual all of this is covered.
Mike
01-20-2002 07:17:47
 Re: Re: CA Fluids in reply to Paul, 01-18-2002 20:06:55
Thanks for clearing up alot of info. I have a shop manual and of course it expects you to know something about tractors. Also, it gives some capacities, not all, however, it does not tell you what fluids, where they go, or how to get them there. I have a two wheel trike front end. What lubricant goes into that chamber?
Thanks again for your help,
Mike
Mike
