D-19 overhaul
Old 57
01-18-2002 08:12:24
Hi, I've put off puting this tractor together for to long and since it gets to hot in the house sometimes I figure this is as good time as any.
This tractor started leaking water in the oil pan. We ended up taking the head off and took it to a very reputable head welding shop, after a thorough examination he determined it was past repairing. I finally found a replacment, got a rebuild kit, had the valves ground and installed, and parked everything.
My delima is I've been told, by different sources, that this probally was A-C's poorest engineered tractor. Mainly in that the engine was for the D-17 and they installed a turbo-charger and didn't have enough radiator to keep the engine cool enough, hence the head problem. SoI'm wondering can I install a radiator with more cooling capicty, which is difficult because of frame comstrictions. Or should I install a
D-17 exhaust manifold and junk the turbo, or just rebuild the tractor as an original D-19 and use it for mowing roadsides and watch the water temp very carefully? Thank you for taking the time to read this message and any input would be appreciated.
Dan Weinert
09-27-2005 15:45:39
 Re: D-19 overhaul in reply to Old 57, 01-18-2002 08:12:24
I can't believe the things I read on here. The D19 diesel is a wonderful tractor and I've never overheated mine once and I work the crap out of it. I had the motor rebuit and the turbo. I took it to be put on a dyno freshly rebuilt and it turned 77HP and let me tell you it is a working machine.
