Aliss chalmers B
beth
01-16-2002 11:14:28
changed oil filter and oil in my B, put new filter on and new oil , fired her up but had no oil pressure toke the filter back off and read the owners manual and i see i threw away the tube that goes in the oil filter and i can not find it, can i relace it with copper or steel tubing, if so what diamiter and how long should it be.
thanks
steve
01-16-2002 18:45:37
 Re: aliss chalmers B in reply to beth, 01-16-2002 11:14:28
the tube is 1/4 inch diameter (.250 inch) and 4-1/4 inch long. It presses into the housing 1/2 inch so you have 3-3/4 sticking out into the filter. There is a hole in the tube that is 7/64 diameter (.110 inch) on the top and a cross hole 1/4 inch down from the top, same diameter. About 15% of the oil goes thru the filter and flows back to the motor crankcase. The rest goes to the bearings and top end valves. Unlike a car that filters all the oil prior to use. After installing the tube, if you still dont have pressure, squirt oil down the steel tube going to the pump. That should reprime the pump. Sometimes they loose prime if oil is changed or they set for a long time.
